Passing Lamps and Turn Signals Mounting
I have an odd set up with my Passing Lamps and Turn Signals... See the pic for details.
I have never seen a lighting set up like mine.
All of the ones that i see, have the turn signals mounted directly below the passing lamps, and it they are mounted with a bracket like this one:http://www.ebay.com/itm/Chrome-Auxil...53.m1438.l2649
But i cant see how i would remove my turn signals from there current location, and "move" them to the bottom side of the brackets shown in the ebay link. Do they even come off that side chrome panel? or is that one whole piece (bracket and turn light - one whole peice?)
Am i wrong? do they mount straight on to the bottom of the ebay bracket? Or do i need to buy new/different turn signals that work with the ebay brackets?
you can put it back under the passing light you just need the spacer the goes between them. and push the wires tru the holes, that mounts is a Street glide bracket .or your bike is a street glide with an Ultra passing lights ?
you can simply removed the side bracket
