On a recent 100 mile hop with the wife, the mileage on my '96 EG was barely 30mpg. My 84 fxr gets well over 40. Are the EG #'s normal for two-up? Thanks.
No, that's unacceptable. My '96 RK routinely got 50mpg riding solo, even higher on the backroads at 50-60 mph. A passenger won't make that much difference unless you riding aggressively and very fast. Mine had a Thunderslide kit installed in the CV carb, which made a 15% increase in mileage. If you run a carb, it is obviously jetted too rich. If EFI, it is programmed too rich. Try a Thunderslide kit with a 175 main (185 if mild cam) and 42 (stock) low jet. If the needle and jets have been tampered with, you may need to change them all.
My 06 (carb) stock got 42 with wife and 45 with just me.
With pipes,mufflers,big sucker,jets,etc.
I get 38 two up and 40 even running single.
Runs like a champ and cooler too.
Mick
Y'all keep in mind that the OP has an Evo, and Evos traditionally get better mileage than TC's, all other things being equal. I wish my new SG would get the mileage my Evo RK did, but it ain't gonna happen, even with all the high-tech add-ons and tweaking in the world. Considering that, his mileage is atrocious and his jetting is likely way off.
