It's been sitting a while...
Old 08-17-2017 | 08:35 PM
fastalkintn's Avatar
fastalkintn
Default It's been sitting a while...
Been a while since I posted anything here, but keep lurking to stay up on things. Anyway, on to my question...I have a 2000 Road King carbureted with 50,000 miles that has been sitting for about 1 1/2 years. I know I know, but sometimes life gets in the way. Besides oil, primary, and transmission fluids what should I check/change before riding it again? It has been covered with a battery tender on the entire time, full tank of gas with stabil in it. Thanks in advance for your help.
Old 08-17-2017 | 08:53 PM
kevin_n's Avatar
kevin_n
Definitely check the tires for rot or flat spots. And even though it had stabil in the tank I would drain it and replace with fresh gas.
Old 08-17-2017 | 09:09 PM
fastalkintn
Thanks for the reply. I plan on replacing both tires, should have mentioned that in the previous post. I am very conservative when it comes to tires. What is your opinion on brake fluid?
Old 08-17-2017 | 09:18 PM
fullautomike's Avatar
fullautomike
I'd ride it for a coupe hundred miles to use up all the gas in the tank, and heat up the oils enough to allow any moisture to "burn off". Then I'd change the fluids, and changing the break fluid is a good idea, and easy.
Old 08-17-2017 | 09:31 PM
lt1-xjs's Avatar
lt1-xjs
A year and a half isn't that long.
Old 08-18-2017 | 04:18 AM
Nikolaiownz's Avatar
Nikolaiownz
yeah change oil, gas and tyres.... and go ride that mother****er
Old 08-18-2017 | 06:35 AM
aviaator's Avatar
aviaator
Drain that fuel! If that is E10 gas in the tank you're probably looking at a carb cleaning/overhaul. E10 clogs the jets if it sits a long time, even with a stabilizer. The voice of experience.
Old 08-18-2017 | 06:41 AM
Notgrownup's Avatar
Notgrownup
It would be well advised that a bike of that age have a good carb cleaning anyway, you will be surprised what is in there after that length of time, find a good Indy and let them do it, change all 3 holes, Brakes??. If it's been a long time , you know it needs to be addressed, do you wrench yourself at all on it?
Old 08-18-2017 | 07:44 AM
trunomad's Avatar
trunomad
I would put a can of SEAFOAM in, ride it and go from there
Old 08-18-2017 | 09:06 AM
Magnut1's Avatar
Magnut1
Brakes, drain the brake fluids, brake fluid attracts moisture. If you don't heat up the brakes it won't dissapate the moisture. Brake pads of course and calipers.
Quick Reply: It's been sitting a while...
