Fast idle on 06 with sert
AFAIK their is no way to get the active calibration off of the ECM so you definately need to get the dealer to give you a copy.
#25, #27 etc. refers to the calibrationnumber. If you look at the tables listing all the calibration files it is the second column in the table.
choochoo, I,ll try the water trick. They just replaced the seals the second time last Thursday. After looking at how they are made, why cant a person use a large viton O ring of the proper size and use Bellville spring washer and nylock locknut to maintain some pressure on the sealing surface. I don,t have access to a old head and intake to play with to see if it is plausible.
