Road King with Laced Wheels?
I have heard that those with the tubeless laced wheels still put tubes in them.
The worst thing about laced wheels is preventing rust on the inside of the rim... it becomes sharp enough that it can cut the tube... even with the rim protector band in place. It is a PITA to seal each spoke on the inside of the rim with something that sticks to the chrome and then you can't adjust the spoke tension.
Profile wheel info:
2009, 2010 used these: 17x3 front wheel Part Number: 44609-09
. . . . . . . . . . . . . . . . . . 16x5 rear wheel Part Number: 44606-09
2011-2013 used these, tubeless: 17x3 front wheel Part Number: 44592-11
. . . . . . . . . . . . . . . . . . . . . . . . 16x5 rear wheel Part Number: 43566-11
2014+ only had cast 17" front wheel, or optional 16" laced steel wheel Part Number: 40960-09
. . . . . . . . . . . . . . . . . . . . . . . . optional 16" laced steel rear wheel is Part Number: 41052-09
they are the same all the way back to 2009 model year
also, the profile wheels came with narrow white walls, the steel ones came with wide whitewalls. nobody makes 17" www tires
Simple washing prevents rust. Problem with some riders is they only wash the front wheel because they don't want to take the time to remove the bags.
But I have experienced a flat from a rusted through rim on my evo softail. It was a very small hole but enough to tear the tube. When I took the wheel to an indy to lace a new wheel, he said that the most common cause of rusted through rims is dogs.
Beary
Buy the Road King you like :https://www.chopperexchange.com/Sear...ic/Motorcycles
Then put these on : https://ridewrightwheels.com/product...torcycle-wheel
http://www.readbag.com/harley-davids...isheets-j05074 or http://docshare03.docshare.tips/file.../251077525.pdf
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Life isn't about waiting for the storm to pass, it's about learning to ride in the rain. WDB
