Black D&D Fatcat exhaust issues
Old 04-14-2018, 12:37 PM
jt metal's Avatar
jt metal
jt metal is offline
Originally Posted by lionsm13
Take em off and clean the rust off and paint them with that BarBq grill paint.
X5...... possibly higher temp product available. D&D is not the only manufacturer dealing with this. Don't purchase black pjpes, period. Going to need maintenance. Idk about Harley product.
Old 04-14-2018, 12:46 PM
Ryan42's Avatar
Ryan42
Ryan42 is offline
Interesting response from them if that is what they said. I had short shots and the worked great but I know the actual pipe was not coated
Old 04-14-2018, 09:12 PM
67Shuv's Avatar
67Shuv
67Shuv is offline
Veteran: Marine Corp
I had some similar markings going on with my black V&H Monster Rounds. I took them off and scuffed them down thoroughly with a red Scotch Brite pad and wiped with acetone. Then repainted with black VHT header paint (rattle can, about $8) and did three light, even coats. Let them sit overnight before reinstalling them. Installed and let the bike idle for about 20min to get them nice and warm. Then let cool completely. Took off for a ride and never looked back. They still look like the day I painted them, and several thousand miles ago.
Full disclosure, I do have a "rubbed" spot on the bottom of one of the tips from where my cover rubs against it when parked in my work parking lot. 12hr shifts in a windy parking lot.... but I had to get under the bike to see the spot. Everything else has held up flawlessly. It's all about prep.
Old 04-14-2018, 09:38 PM
Olsen185's Avatar
Olsen185
Olsen185 is offline
Funny that this came up again because I finally took care of my pipes today. I used John Deere exhaust paint, and I think it turned out pretty good! It’s not a perfect finish, but most of the imperfections happened when I put the heat shields back on the bike.
Old 04-14-2018, 09:39 PM
Olsen185's Avatar
Olsen185
Olsen185 is offline
Old 04-14-2018, 10:16 PM
SnoRider's Avatar
SnoRider
SnoRider is offline
Glad you posted this thread!
Old 04-15-2018, 07:50 AM
D J Gilbert's Avatar
D J Gilbert
D J Gilbert is offline
Stage II
Default chrome
Originally Posted by Olsen185
Do you think that would work on chrome?
Old 04-15-2018, 01:39 PM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
No because it had nothing to do with me. When it rusts from under the coating it was the surface prep prior to coating. Their stance was that the finish doesn't last forever.
My pro pipe did the same thing on the muffler body after a year or so. V&H had basically the same response. If I remember right he even said I was lucky to get a year.
Old 04-30-2018, 08:04 AM
HDK's Avatar
HDK
HDK is offline
This is all good to know. Guess I’ll be finding a reason for mine to be returned before my year is up on the warranty. Not dropping $600 on something that won’t last a year without rusting especially since there was no mention of that fact from them on the front side. I was told by the dealer not to use any polishes on the pipes. Soap and water only. Not sure if that’s accurate now or not. They are Bassani and not the brands mentioned but I suspect finishes are all the same.
Thanks,
fxbrry
08-11-2020 06:07 PM
InMotionJosh
The "Florida Crew" Classified Section
08-23-2015 06:35 PM
07bobber
06-13-2012 06:03 PM
Quick Reply: Black D&D Fatcat exhaust issues
