Oil plug metal shavings
Old 07-30-2017, 09:23 PM
Olskool555's Avatar
Olskool555
Olskool555 is offline
5th Gear
Default Oil plug metal shavings
Little freak out bike is new to me 05 Electra glid 88 supposed to have gear cams in it....chatting as f...k compression 125 on both cyl. Oil pressure is good any thoughts???
Old 07-30-2017, 09:31 PM
UltraZac's Avatar
UltraZac
UltraZac is offline
Wow, how many miles/kms. Last time I changed my oil, I had one small speck at 60,000 kms. I would be looking into that, or ride it till it blows up.
Old 07-30-2017, 09:35 PM
Olskool555's Avatar
Olskool555
5th Gear
74000 mile
Old 07-30-2017, 09:41 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
Hate to say this - but that doesn't look good. If it were me i would pull the cam cover, cam support plate and cams; look for metal. Could be an inner cam bearing granading. Check the oil pump for wear and tear.
Good luck.
Old 07-30-2017, 09:48 PM
Olskool555's Avatar
Olskool555
5th Gear
Definitely have to start somewhere..do you think I would hear crank bearings?
Old 07-30-2017, 09:50 PM
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
Unlikely.
Old 07-31-2017, 08:21 AM
GTK's Avatar
GTK
GTK is offline
I forsee a total engine rebuild or a new engine in your future.
Old 07-31-2017, 09:23 AM
0lowrider1's Avatar
0lowrider1
0lowrider1 is offline
I would definitely pull cam cover and check the gear drive..
Old 07-31-2017, 11:52 AM
BB59's Avatar
BB59
BB59 is offline
That is just what made it to the magnetic plug. Im betting cam bearing but you won't know until you tear it apart. That is a lot of metal to have circulating around your motor and will play hell on other bearings, oil passages, oil pump etc.
Old 07-31-2017, 06:41 PM
UltraZac's Avatar
UltraZac
UltraZac is offline
Yep, I would be pulling the cam case cover off. That's allot of shavings. Your oil pump must be hurting with all those shavings floating around.
Quick Reply: Oil plug metal shavings
