Pushrod adjustment with milled heads?
Old 07-22-2017 | 06:16 PM
m_mcdonnell314's Avatar
m_mcdonnell314
Default Pushrod adjustment with milled heads?
Hi all- quick question here. Got my heads ported, polished, bigger valves, compression releases etc. but also got them milled approx. .050 for more compression. I am running a .030 head gasket as well. I know the standard safe zone for a lifter is around .100. Question is, I have to account for the .065 reduction (stock head gasket is .045-.030=.015 plus the .050 milled from heads) when adjusting the rods, right? I have S&S rods with 32 TPI. I forgot how many thousands of an inch are in a "flat" but once I figure that out, i would subtract that from basic adjustment.
Just Dy double checking. Thanks for any input.
Old 07-22-2017 | 06:23 PM
QC's Avatar
QC
4 turns from zero lash to get to .125 pre-load. Approximately .005/flat.
Old 07-22-2017 | 06:48 PM
m_mcdonnell314
Wouldn't I have to subtract .065 from that since was I stated above? If it's approx .005 a flat, that is 13 flats. Thinking about it that doesn't seem to right? Seems very excessive
Old 07-22-2017 | 06:57 PM
Uncle Chester's Avatar
Uncle Chester
Milling your heads and gasket thickness won't change the procedure for installing the push rods. If you take them to zero lash and then apply the correct number of turns the preload on the lifters will be the same regardless.
Old 07-22-2017 | 07:02 PM
uscanuck's Avatar
uscanuck
Maybe I'm missing something here but the reduction in height on the top end would only come into play if you were going to buy solid push rods.
You're using adjustable push rods so you would set them the same way as if it was all stock. 32 TPI = 3.2 turns = 0.100
Since you have bigger valves, milled heads and smaller head gasket I assume you checked your valve clearances already.
Old 07-22-2017 | 07:09 PM
m_mcdonnell314
Wow! I feel like an idiot. It just "clicked". And yes, it was measured already. In the clear. Thanks everyone! Tail is between the legs now...
Old 07-27-2017 | 04:32 PM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
That's OK, we still like you.....
__________________
LONG RIDE SHIELDS
www.longrideshields.com
fireaxxe
02-02-2011 06:08 AM
softail99custom
EVO
01-21-2010 08:45 AM
outback2970
Exhaust System Topics
02-08-2009 01:57 PM
BUSTERK
08-07-2008 02:44 PM
gamb
04-10-2008 10:05 PM
Quick Reply: Pushrod adjustment with milled heads?
