my 2 problems with them are the clutch side fit a little loose and needed a thin shim, other is the lever won't make the clutch switch when adjusted close in.
Make sure you can get enough pull to separate the clutch plates sufficiently. I couldn't when I went to a Bandit sportsman clutch, so went back to stock.
The other statement regards the lever won't make the clutch switch when adjusted close in is also correct.
Just a note , on some bikes the clutch switch works fine with the adjustment set on one, My bike never had a problem starting in gear with clutch pulled in.
