Looking to add led brake lights to rear of hard bags
Old 07-18-2017 | 04:57 PM
RKGD's Avatar
RKGD
Default Looking to add led brake lights to rear of hard bags
Ive seen a few of you guys with extra led brake light set ups on your baggers. Ive been searching them out aftermarket and see quite a few options. Which ones do y'all run and recommend?
Old 07-18-2017 | 05:35 PM
Buelligan666's Avatar
Buelligan666
My setup from my old bike:
Radiantz Amp'd LED strips on the bags and tour pak spoiler. Cycle visions eliminator tail/license plate holder. Custom dynamics tri-bar. I run the turns on the bags off of a Hopkins self powered anti-short trailer wiring adapter. I get a lot of compliments on how bright everything is.
Close up of the led strips.
In bright sunlight
In the garage.
RKGD (07-18-2017)
Old 07-18-2017 | 05:44 PM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
www.customdynamics.com
Has everything you need.
Old 07-18-2017 | 05:46 PM
AFSOC_Commando's Avatar
AFSOC_Commando
I am running the Custom Dynamics The 3 links below... Not cheap but MUCH brighter and better quality then the HD similar parts
https://www.customdynamics.com/fillerz-chrome
https://www.customdynamics.com/bagz-saddlebag-leds-bcm
https://www.customdynamics.com/magic...vidson-touring
I believe in being seen and the Magic strobe allows me to pick a flash pattern when I am braking which really gets folks attention. Since putting them all on I see a huge difference in the cagers tail gate me. I can hit the brakes for a second and catch their attention when they start crowding me.
Good luck!
RKGD (07-18-2017)
Old 07-18-2017 | 05:53 PM
slapshot12's Avatar
slapshot12
I run the HD bags lights for the Rushmores. CD makes great stuff and carry about any motorcycle light you'd need if the HD aren't an option. I'm a firm believer in extra rear lighting. I have the stock tour pak lights, bag lights, and a BAL brake light.
Old 07-18-2017 | 08:21 PM
smokingjoe's Avatar
smokingjoe
I run the HD LED bag lights, plenty bright.
Joe
Old 07-18-2017 | 09:42 PM
bklynbob's Avatar
bklynbob
Take a look at
www.radiantz.com
They have just about anything you need. The Puckz mount to your bags. If you have a streetglide type light bar check out their cyclops. I have their front and rear signal inserts. One fubared after 5 years and they sent me a new one.
RKGD (07-18-2017)
Old 07-19-2017 | 12:26 AM
OldPhat's Avatar
OldPhat
Tell us what year your Bike is, if it's 2014 or newer I'd get the HD Electra Glo
Saddlebag-Run-Brake-Turn Lamps. If your Bike is 2013 or older, Custom Dynamics
is the way to go.
John
RKGD (07-19-2017)
Old 07-19-2017 | 12:32 AM
Yazeed's Avatar
Yazeed
I run the following parts on my FLHX 2015:
Tri-Bar Light Upgrade 67774-10
Light Bar with LED Bullet Turn Signals 67800491
i'm sure the
Old 07-19-2017 | 08:31 AM
RKGD's Avatar
RKGD
Thanks for the varied suggestions so far.
I should have stated for fit purposes that I have a 2011 RK. Nothing in the rear is modified yet.
Quick Reply: Looking to add led brake lights to rear of hard bags
