2007 road king noise
Old 07-18-2017 | 01:13 PM
2007 Road King Lou's Avatar
2007 Road King Lou
Stage IV
Default 2007 road king noise
Today when starting my 2007 Road King with 22,000 miles I heard a grinding sound, then it started up. Sounded pretty nasty. Any ideas? Thanks in advance.
Old 07-18-2017 | 02:53 PM
Buelligan666's Avatar
Buelligan666
Weak battery or bad connections would be the first place to check. If that's all good the starter clutch could be going bad.
Old 07-18-2017 | 03:48 PM
2007 Road King Lou
Stage IV
Sounded Pretty nasty. Ill check the battery and connections tonight. If its the starter clutch, I need to replace the entire starter? Thanks
Old 07-18-2017 | 09:11 PM
6 gun's Avatar
6 gun
Originally Posted by 2007 Road King Lou
Sounded Pretty nasty. Ill check the battery and connections tonight. If it's the starter clutch, I need to replace the entire starter? Thanks
No way Jose! just the starter clutch, they are a lot cheaper than the whole starter. If you cant get one from Harley get an aftermarket one.
Old 07-18-2017 | 11:33 PM
CZshooter's Avatar
CZshooter
If its the starter drive, its not long for this earth. Mine died pretty quickly after it acted up the first time...like I got 2 or 3 more starts, then ZIIINNGG all you hear is the starter motor spinning. Its a one-way clutch, when it fails, it just spins and does nothing. If memory serves you'll need a Primary cover gasket also.
i put one of these in:
https://www.amazon.com/All-*****-79-2101-Starter-Assembly/dp/B000GZQNBO/ref=sr_1_1?ie=UTF8&qid=1500438249&sr=8-1&keywords=All+*****+79-2101+Big+Twin+Starter+Clutch+Assembly https://www.amazon.com/All-*****-79-2101-Starter-Assembly/dp/B000GZQNBO/ref=sr_1_1?ie=UTF8&qid=1500438249&sr=8-1&keywords=All+*****+79-2101+Big+Twin+Starter+Clutch+Assembly
Been working good for a year now. My bike will sometimes pop and hammer back against the starter, which took the first one out. (2 actually..I put a crappy starter in it after the first one failed, my bike ate that one in a week) Buy once, cry once.
Old 07-19-2017 | 03:46 AM
bigpayback21's Avatar
bigpayback21
Could be the compensator. Mine sounded terrible just in start up. Went to SE been problem free for 2 years ...
Old 07-19-2017 | 06:41 AM
Bubba Zanetti's Avatar
Bubba Zanetti
This^^^. Same thing on my 09
Old 07-19-2017 | 08:37 AM
beary's Avatar
beary
I's hard to tell. I thought my starter clutch was going out, but someone told me I was letting off the starter to early. Sure nuff, I haven't had a problem since. I'm so use to my 2014 Limited firing right up that I was starting my 07 the same way. I just needed to hold the starter in a micro thump longer to make sure the engine was turning on it's own. I've own 8 Harleys and this is the first with this personality of starting.
I would check the battery first.
Beary
Old 07-20-2017 | 07:33 AM
2007 Road King Lou
Stage IV
Thank You all, My buddy coming this weekend and take a look with me. I hate to bring to HD, always fell like I'm being robbed.
aspiringthomas
05-03-2019 09:17 PM
vrrnitro
06-11-2013 01:27 PM
jbyrd1173
11-02-2012 12:47 PM
dsbducracer
05-21-2011 11:35 PM
dualsport
01-05-2011 03:29 PM
Quick Reply: 2007 road king noise
