Help Installing AUX Driving Lights
Hi All -
I recently purchased the following lights for my 2017 SGS.
https://www.harley-davidson.com/stor...-led-fog-lamps
With this wiring harness.
https://www.harley-davidson.com/stor...11-69201109--1
Now for the life of me I can't figure out where to plug the harness into the bike.
I also installed the factory light switch from an Ultra that goes next to the key location. The switch is already wired and shows power when depressed.
Any suggestions.
Any suggestions.
From the instructions with your harness:
- Install the fog lamps and mounting brackets to the vehicle per the instructions in those kits.
- If NO auxiliary lamp switch is present:If an auxiliary lamp switch IS present:
- See a Harley-Davidson dealer to purchase an original equipment (OE) auxiliary lamp switch for this year/ model vehicle, OR
- Use the universal LED Bullet Fog Lamp Harness (Kit No. 69200863) instead of this kit.
- Bat Wing models: Access the four-way auxiliary lamp connector [31] on one side. Separate the connector halves. Plug this harness in between the two separated connectors.
- Frame-mounted fairing models: Remove outer fairing. Find four-way turn signal lamp connector [C31]. Plug this harness in between the two separated connectors.
- See Figure 1. Route the two harness legs and connectors (2) downward to the base of the front downtube. Plug the harness into the fog lamps.
- Coil up any excess wire. Use cable straps (7) to secure the harness legs to the engine guard.
DeadBirdDog
2014-2023 Touring Models
13
07-02-2015 04:30 PM
