Another Harmon Kardin Issue!!
Hi all.
I've got an 06' Ultra...
I ordered the Hogtunes speakers the other day...very excited to get them as I've read they make a nice difference...
So, in planning to get them I decided to update my radio software just to make sure I was fully "optimized"...
What a dumb decision that was...
(You know the ol' saying "if it aint broke..."?)
Anyway, I download the software, burn it to a CD, go through the motions of installing it...
It's installed but NOW my radio is TOTALLY LOCKED THE HECK UP!
The display comes on, it looks normal however there is NO sound and NONE of the controls work...
I tried the "hold two softkeys" deal to get to the diagnositics menu and because the darn thing is locked up it's not even recognizing me touching the softkeys so I can't get to that menu...
Then I read that if you disconnect the MAIN fuse for an hour or so, it will fully reset the radio...did that and NO luck!
Now what!
I'm 99% sure my hogtunes speakers are showing up tomorrow but right now, I've got a non-responding radio!
I need help!
Thanks in advance!!
Now what!
I need help!
Thanks in advance!!
RE: Another Harmon Kardin Issue!!
ORIGINAL: Biggzed
Is the CD still in the stereo? Have you tried disconnecting the battery and re-connecting? I know pulling the fuse should do the same thing, but you never know. CTRL + ALT + DELETE?
ORIGINAL: stevenbekahs
Yup, the CD is still in there...and yes I tried disconnecting the battery. Like I said, the DISPLAY looks normal...like it would when you just start it up to head out for a nice ride...it's just FROZEN completely...no sound and none of the buttons on the radio work and none of the switches on the bike work. There must be another MASTER reset somewhere on this @$@#$@#$@% thing!!
This isn't exactly your problem, but you might try it. You said you pulled the fuse, but was it the maxi-fuse?
Along the same conversation... Is there anywhere a person can find the OLDER versions of the software? I have upgraded each time myself and think at times that the older software had less issues at times.. and of course I didnt save them each time I downloaded the newer one...
ORIGINAL: jrudicel
