Tuners, CAT, heat, and stuff
Wondering a few things; 2015 FLHXS
Has anyone ever put the CAT back on?
Have I just forgotten the unbearable heat?
Can you use a tuner with the CAT in place to help reduce the heat?
I enjoyed the sound of my bike on long road trips with the CAT in place vs the last 20k miles without, but I enjoy the heat reduction now without. I also enjoyed the odorless exhaust with the CAT, but enjoy the free flow exhaust without.
I know....[*everyone rolls eyes]
Exhaust
Hey,
I just got rid of my Street Bob. I had V&H Big Shots on it, ceramic coated black. I loved the pipes, but they wore on me on long trips.
What I did was buy a set of the V&H quiet baffles (the kind you can wrap with fiberglass). I swapped those out a few times with the standard baffles. I found I liked the lower, deeper tone of the quiet baffles over time and ended up just leaving them in.
Not sure if this helps, but it's a heck of a lot easier than messing around with the head pipes. Only takes about 15 minutes to swap out.
If the V&H baffles won't work for you look at Big City Thunder. They have two or three types that will fit most pipes.
Hey,
I use a PowerVision now, works great. Didn't know if you tuned with the CAT would it decrease the heat over the stock tune setup?
I've had enough of the heat on my Triglide but I didn't spend as much money as I did on my Ultra where I spent a bundle on true duals, SE Stage 1 air filter and PC-V so I went the cheaper way: decatted headers, K&N Stage 1 air filter and FL-ViED 10.
I didn't buy a trike to make it run like a raped ape. It's all about comfort and reasonable performance 2-up, nothing else. Wait, there's something else: sound. If I don't like the sound of my V&H slash round with the decatted headers, I'll put CFRs like I did on the Ultra. I've yet to hear better sounding pipes and I've pretty much heard them all.
my crossover is starting to show the miles and starting to rust through. i noticed it the other day when i was messing with the tires and cleaning the bike. i kept the original header pipes so, i might put them back on along with the stock mufflers. i have some rc exhaust and header pipes that have about 45000 miles on them. might be a good project at the end of summer. will have to break out the cat from the original pipes. i don't know if you can ever manage the heat. i think its just a byproduct of putting your a$$ on top of a V-twin.
IMO, running catless, whether it's decatted stock headers or aftermarket, is a no-brainer. The cat is a furnace and there's no good solution other than getting rid of it one way or another. Not saying sitting on top of an engine is not going to be hot but there's no justification for making the situation worse by keeping the cat.
