Notices
EITMS Scary situation
Old 07-02-2017, 07:07 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Originally Posted by 10 RED RK
How do I fix it so that it does not happen again?
pull the codes from the ecm- you will be able to track down whether you have a throttle position sensor or servo motor problem.
suggest you start by pulling connector from servo motor and reattaching- that alone can clean the connections and solve the error.
as above eitms is programmed to come on with no throttle input and speed below ( i think) 3 mph..so like sitting stopped at an intersection.
this turns off fuel and spark to rear cylinder ( the hotter of the 2) and it will just pump air through to remove heat.
pretty smart when you live in the desert like I do.
it comes on once in a while, not often.
i'd rather have a goofy sounding idle than a toasted motor!
Mike
10 RED RK (07-02-2017)
Old 07-02-2017, 07:20 PM
big- mike's Avatar
big- mike
big- mike is offline
I just told you get some contact cleaner first start with the harness that plugs into the throttle body unplug it clean the contacts inspect the pins for damage put some dielectric grease on it and plug it back in.what I did was open everything up and did all the connections including the ecm I also loosened some tight zip ties with doing that my bike hasn't gone into limp mode since and that was 4 years ago
Old 07-02-2017, 07:33 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is online now
Received 17,824 Likes on 7,249 Posts
Are you sure it just did not go into limp mode?
Any codes. My 2010 did that once and it was the connection behind the air cleaner. Pulled it apart, cleaned, packed with dielectric grease and never had another problem.
Old 07-02-2017, 09:50 PM
bmaier's Avatar
bmaier
bmaier is offline
Yep, definitely limp mode, should have lit up the the check engine light too, pull the codes and follow other posts advice for troubleshooting and repair.
Old 07-02-2017, 10:08 PM
leftyjm's Avatar
leftyjm
leftyjm is offline
If you google "Limp mode on a Harley" it will answer a lot of questions. Also a good video for 1.54 mins
Old 07-03-2017, 06:33 AM
1HD1C's Avatar
1HD1C
1HD1C is offline
Originally Posted by vistavette
eitms only works at idle, not in a parade, slow speed etc. If the bike thinks it's hot enough to turn on while you're sitting i let it. I'll never understand why some think it hinders their ride.
this!!!
Old 07-03-2017, 06:42 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
Also, any recent electrical upgrades and/or do you have a tuner on the bike? These could be associated to your issue. If not, and you can't figure it out, get bike in for svs. Definitely a "butt-pucker" situation. ( )*( )
Old 08-04-2020, 05:48 PM
Padre's Avatar
Padre
Padre is offline
Received 1,232 Likes on 533 Posts
I've read the newer bikes like mine (2020 Fatboy) have eitms. But supposedly it is automatic and not throttle related? Is this a correct reading of what I can find online?
Old 08-04-2020, 06:04 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 30,475 Likes on 11,476 Posts
EITMS will not engage if bike is moving, so your issue was not EITMS. I’d check for codes, sounds like you went into limp mode.
Old 08-04-2020, 06:20 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,576 Likes on 2,711 Posts
It's enabled/disabled by rolling the throttle forward when stopped. Then it will come on as necessary, automatically, when you are stopped
Quick Reply: EITMS Scary situation
