Right passenger backrest
With the new bike, I had them throw in the passenger backrest and docking hardware. Tried to pull it off yesterday and that thing was weighed on there right. There's about an eighth of an inch on the outside of the connection point. I got it off. Though it's just as tight going back on and the latches are really tough to move back into place. I changed the installation diagrams and they all appear to be I there correctly. Anyone else have this issue with a new backrest?
Received 75,623 Likes
It looks like it should just pivot off?
Yeah. Normally it slides on, the latch rotates around the quick disconnect hardware, and there's a stopper that holds it in place. To remove it, you lift up the stopper and rotate the latch back. Problem is its so tight, you can't rotate the latch by hand.
^ There's that and also the mounting points can be flipped so that the thicker side is either on the outside or the inside creating the right spacing as well. Problem with having HD install the docking hardware is that, if you don't already have a backrest for them to test fit, they don't know how to set the spacing.
Looks like your latches are pressed against the inside of the mounting point leaving that excess space on the outside. Flip the mounting point around so that the thinner side is on the inside and it will free up the latch.
Thanks for that. I will look at it closer when I get off work. Unfortunately HD had everything and installed everything. I only noticed it was that tight 5 days later when I went to remove it. I will play around with it when I get off work.
rziraschi
07-15-2017 08:21 PM
river rat
03-11-2010 12:57 AM
Sledge
08-31-2008 07:42 PM
