cruise control not working
Received 4,808 Likes
The CC light doesn't come on at all or just won't go green? If not at all start with fuses.
If it just wont engage then some of the things it could be are, brakes not releasing, brake lights remaining on, bad roll off switch, speed sensor, no signal from tach, bad switches/controls, wiring problems, loose or corroded connectors among others.
The FSM has a complete troubleshooting guide or I'm sure you could find it on YouTube
The most common cause of Cruise control failure to engage is the brake lights being lit all the time. If the brake light circuit is activated the cruise control will not engage.
Check whether your brake lights are working or not. Most common cause is the rear switch going bad. Simply remove one of the wires going to it and see what happens.
The second most common cause is the roll off switch in the throttle return cable. Simply remove one of the wires going to it and try setting the cruise control.
Spy11 (01-22-2018)
Wasn't sure if I should dig up an old thread or start a new one. I replaced the handlebars and broke the stop lamp switch. It looks like a pain to replace the switch. It still functions manually pushing it. Anyone had any luck just putting a tiny screw or something similar? I'm going to try and re-align it as I don't see much difference between what's on the bike and what I see in pictures, but I'm sure it won't be that simple.
