Is it my fuel pump?
Is it my fuel pump?
Riding home from work today and stopped at a traffic light. As I sat there the bike was running great one minute and the next it coughed sputtered and stalled. I tried to restart it and it just cranked and coughed. It finally did fire at one point for a few seconds and sounded like it was on one cylinder. I changed the plugs and it fired for a few seconds then died. The fuel pump sounded different to me every time I would turn the key on and it would prime. 2008 ultra classic with 58,000 miles. Cams, breather and PC5.
You need to check your fuel pressure. There are several things that could be going on inside the tank. It could be the fuel pump, fuel pressure regulator, fuel filter or even leaking fuel lines inside the tank. You can eliminate all of these by knowing that you have proper fuel pressure during the initial prime and also when the motor is running. Pressure should be between 55 and 60 pounds and it should hold for a bit when you turn the motor off. If your pressure is good you know to look elsewhere for your problem.
Here is the tool I use. It usually stays in my Tour Pack when traveling. Probably cheaper than paying for the dealer to test for you. They are available online from a dozen different sources
http://www.pdi-racing.com/fuel-tool-...s1AxoCWnnw_wcB
Here is a link to a you tube video on how to use it.
I bet it is fuel pump related. I've had the fuel filter shell break at the retaining pin tabs twice. I noticed the last new one was more than twice as thick so they recognized the problem. Remove the top cover retaining ring and lift the cover a little. Then shine a flashlight into the tank and turn on the ignition. If you have a leak you will probably be able to see it. Wear safety glasses.
Same symptoms I had when the fuel filter canister broke. With the cap off the tank, when turning on the ignition, fuel rushed around in the tank during the prime sequence. No mistaking there was a leak in there but did have to remove fuel filter/fuel pump/ fuel level assembly to see the source. There was a recall on some 2008 machines for the fuel filter canister, my 08 was not on the list but the canister eventually broke anyway. The holes worn in fuel lines are a distinct possibility BUT they usually have a slow onset of poorer and poorer running rather than sudden onset of no running. If you can hear the fuel pump, I would bet on the fuel filter canister.
No one has ever explained why, but sometimes the fuel quick disconnect on the bottom of the tank won't pass fuel. Disconnecting it and reconnecting usually restores flow. That is a quick and FREE thing to try.
