Who mounts tubeless tires on tubleless spoke rims?
Old 01-02-2019 | 12:28 PM
jimglassford's Avatar
jimglassford
I thought the benefit of the tubeless wire wheels is that you could plug a leak while on the road versus having it towed to a dealer to patch the tube. I would take the rim to a tire place that works on rims. I know I see advertisements every so often for wire wheel repairs for some of the old British cars. The corrosion area may be polished or filled with a compound to solve the leak problem. The allow wheels are susceptible to corrosion as well. I wonder if dealers just throw in tubes on these when they leak because it is easier. I would want the rim repaired versus buying a new rim or installing a tube.
  #52
Old 01-24-2019 | 04:16 AM
RoadKingMD's Avatar
RoadKingMD
The benefit is there but I guess only if there is a small puncture to the tubeless tire. I my case the inner sealing rubber got displaced - something you cannot fix on the road.
From what I know this is correct - people / dealers throw on the tubes to fix (serious) problem.
We will soon see the extent of corrosion and if it can be fixed. Otherwise I'll probably with a new OEM tubeless.
B Bop
07-15-2017 01:13 PM
B Bop
07-02-2017 01:34 PM
B Bop
Wheels/Tires
06-06-2017 03:05 PM
hyrax222
EVO
13
03-03-2015 08:52 PM
THNDR
02-19-2008 06:49 PM
Quick Reply: Who mounts tubeless tires on tubleless spoke rims?
