Cams for 05 Road king
Hello , Any ideas about what cams to use for 05 Road king carb, with 100"S&S big bore cylynders I installed this year. Want to keep chain drive and maybe easy start S&S 585,Also how do I know compression ratio? piston Compression Height is 1.270, piston weight is415, Dome Volume 9.73, Dome Height.165. Plan on heads down the road. Thanks
Link ...
Try inputting your #'s here ....the more info you can provide the closer you'll be ...
you'll need to know what the compression ratio is then you'll be able to select the cams better !!!
http://www.bigboyzheadporting.com/TwinCamComp.htm
Received 14,667 Likes
