Rear tail light on end of fender
i just went thru that, there is no light inside the fender light, but there is the harness that plugs in from each side of it, this harness goes thru the light and up to power the turn and brake light on our candian bikes, what i did was open the light up yes it can be done carefully and install a small strip of LED from walmart and tap in to the harness, if you want plug and play Custom Dynamics sells a plug and play unit that will provide brake and running light capabilities, below is the link for the canadian bikes
https://www.customdynamics.com/rear-...ide-road-glide
Check this out
http://dreamcyclescanada.com/index.p...ducts_id=25696
Canadian company and Canadian funds.
Randy Oblong
2014-2023 Touring Models
16
06-01-2018 01:41 PM
