Do I have a bent swing arm?
Long story short...
When attaching my shocks...One goes in...the other is about 1/2 inch different.
With the swing arm removed sitting on the bench...and the bolts to the chain guard removed...there is a noticeable difference in height at the axle ends. You can push down on one side and make it wobble.
Should it lay flat...?
08 SG
Thanks for your input!
smat
08 SG
smat
TwiZted Biker (06-01-2017)
From your description, I think it being bent is highly likely.
The shocks should both thread in at the same height. One should not be higher or lower than the other in the mounts.
While the welding on the swing arm can make it wobble due to variances, it should be very minor. As described above, the swing arm shaft and the axle shaft should be parallel.
When I put Ohlins on my Limited, I had to adjust one shock about 3/8" longer than the other for it to slide on easily. Howard @motorcycle metal said it's common.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Had an accident 3 years ago...it was front end...never really checked the rear...
Fought this thing for 25k...So I picked up a good used swing arm off an 07...$112.00 (used) vs $1400 (new)
Installed new bushings and bearings and spacers and rubber mounts.
Did an alignment and back on the road!
Thanks for all the input!
smat
smat
