Brake pad replacement Blunder?
Old 05-20-2017, 02:54 PM
jeffreydsilver's Avatar
jeffreydsilver
jeffreydsilver is offline
Default Need Someone With A Service Manual
Originally Posted by Rickr01
This is the only ABS bike I've ever done.
Originally Posted by btsom
It is "industry standard" NOT to push used fluid back into an ABS system when pushing the pistons in for new pads but to open the caliper bleed screw and let the fluid out at that location.
I know this to be true of cars but if anyone here has a service manual with a Harley ABS section in it, it would be helpful to chime in on proper procedures!
Old 05-20-2017, 03:15 PM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,072 Likes on 2,507 Posts
I can't say what the industry standard is but I:
Clean the pistons before pushing them back in.
Put a hose on the bleeder valve and open it before I push the pistons in.
I do this to my ABS and non ABS Harleys.
I use DOT 5 fluid in my non ABS bike and it gets changed every 2 years. I use DOT 4 in my ABS bike and that gets changed every 12 months without fail. Additionally, after I flush my ABS bike, I button everything up and go for a test ride where I engage ABS on the front and rear wheels (separately) ten times. Then, I go home and bleed the system one final time to insure I purge the fluid previously captured in the ABS HCU.
One final note; every time I ride my 2011 with ABS I engage it at least once using stutter bumps, gravel, wet pavement or rough lever/pedal engagement. There have been a number of ABS HCU failures that resulted in a frozen pedal or lever that rendered the brake completely inop. I'd like to avoid that if I can as I'm an aggressive rider and wouldn't like to have such a failure at the entry of a fast sweeper.
Old 05-20-2017, 04:01 PM
HOGNOT's Avatar
HOGNOT
HOGNOT is offline
Here's a youtube.com video on proper procedure for ABS equipped Harleys:
Old 05-20-2017, 04:35 PM
Campy Roadie
This is nothing more than a video on how to bleed ANY brake system on a Harley or other motorcycle; ABS or not. It does NOT bleed or exchange the captured fluid in the HCU. For an ABS bike you have three choices:
Have the dealer do it and they will activate the ABS HCU during the proce$$.
Do what I described above.
Do what the posted video says to do and hope the new fluid eventually purges the fluid from the HCU.
https://www.youtube.com/watch?v=_tddIQ3uuBs
Old 05-21-2017, 09:52 AM
bill from tn's Avatar
bill from tn
bill from tn is offline
I replace the pads when installing new tires, every time. The calipers have to come off anyway and the price of pads hardly puts a dent in my bill for tires and install.
I had the dealer bleed/flush my ABS system last fall. They also replaced the front master cylinder cap with an upgraded cap and gasket. I think the bill was just a little over $100 for flushing the system, fluid and the new cap. Pretty cheap to keep the system up to specs.
I agree the ABS should not default to no brakes due to fluid contamination but this is the system Harley sold us.
Old 05-22-2017, 12:41 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
I'm the original OP. I changed my brake fluid before I put her up for the winter so fluid was brand new. Piston bores were cleaned. I took the bike out for a long ride this past weekend and after a few fade in brake stops the brakes felt perfect. It just took a few miles of use.
Not loosening the Master Cylinder covers when I pushed the pistons back in the bores to install the new pads does not seem to have had any ill affect on the brake system or ABS. Next time I'll loosen the cover....Lesson learned.
Old 05-22-2017, 01:34 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,529 Likes on 1,424 Posts
Great news. Ride safe!
Old 05-22-2017, 02:31 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Yeah, this is what worries me. Just yesterday I spent hours with a brother working on his 2006. Of course a non ABS bike. But the point is, his fluid looked like CRAP! And now I'm thinking the fluid in my ABS box is gonna wind up the same way, even with the frequent flushes I do. So yeah, I'm gonna head to the dealer and pay the fee for a proper flush.
Old 05-22-2017, 06:49 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
It is "industry standard" NOT to push used fluid back into an ABS system when pushing the pistons in for new pads but to open the caliper bleed screw and let the fluid out at that location. If you have a VERY hard pedal, you may have had the infamous ABS hydraulic lock happen at the same time as your brake change, just a matter of bad luck, but likely not the cause. If you ultimately determine this is your problem, replacing the ABS unit is the only fix.
Touché - I've made it habit that when ever I replace my brake pads, I push them out further than normal and clean them up really good with simple green and apply brake grease around the pistons. Then I flush a bottle of brake fluid through the system before I push the pistons back in. Once the calipers are back on and the pads are installed, I seat the pads against the rotors and do one more flush and set the fluid level correctly. I always use new gaskets for the master cylinder too. I figure the system needs to be flushed every two years any way and brake fluid is cheap enough, it's just good insurance to prevent the hydraulic control unit from crapping out. Probably more work than necessary but my brakes have always been flawless so I'm not changing anything.
Old 05-22-2017, 06:55 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
The dealer does NOT activate the ABS during the bleed process. The digital technician activates the HCU after the bleeding process is done to ensure any trapped air in the HCU is worked loose, than a second bleed "may" be required if it didn't function correctly. I've done this a couple times with the digital tech and it's not required if don't introduce air into the system. A proper flush won't put air in the line.
Quick Reply: Brake pad replacement Blunder?
