HowTo make Passing Lamps work on both low & high beam
I have a 2011 Ultra Classic TriGlide
When the Headlight is on Low Beam the Passing Lamps work.
When the Headlight is on High Beam the Passing Lamps DO NOT work.
I want the Passing Lamps to work on both Low and High beam.
What's the solution?
Not sure when it started, but for at least the Rushmore bikes (2014+), dealer can flash the "brain" to allow both sets of lights at the same time. Don't know if that is what you need to do for your year. Someone here will likely chime in with the info, or just call a dealer, they'd be the ones doing the flash anyway, if your bike is set up for that.
r-bar-j (12-12-2022)
The spotlight switch is powered off of the wire to the low beam. Find another source of ignition power and splice into there. I've done it with ease with my previous Street Glide, ended up splicing into my high beam wire instead. Get you a factory service manual to help you find a ignition power source. Pretty easy deal.
tar_snake (04-19-2023)
Here ya go, part # 69200441 $29.95
https://www.harley-davidson.com/stor...re-harness-kit
There's a way to wire it without this harness, but as inexpensive as the harness is, why mess with it.
The following 3 users liked this post by Talldog:
I also installed this harness, works great. The only thing you will find is the acc switch in dash will be on at all times even when showing off. As log as ignition is on.
Received 2,530 Likes
The following 6 users liked this post by TheGrandPoohBah:
95hdtlk (05-22-2020),
dodger413 (05-19-2017),
JohnValhalla (09-18-2021),
mctraveler (05-20-2020),
scooper321 (05-19-2017),
and 1 others liked this post.
That was a government thing, many of the states required the passing lamps to be wired into the low beam. Reminds me of many moons ago when the government made Harley have the headlights on at all times. There was a white wire you simply gut. Like others said, plenty of power leads up front just wire it to a switch.
Thanks
