Cheapest easiest way to make stock radio Bluetooth?
Old 05-13-2017, 03:06 PM
bobby5's Avatar
bobby5
bobby5 is offline
Default Cheapest easiest way to make stock radio Bluetooth?
I have a 09 street glide and want to make the stock HK stereo bluetooth. i did searching but every thread i found was like 5 years old. i was wondering what was the easiest and cheapest way to add bluetooth without a bunch of wire showing. I saw were hogtunes had a bluetooth adapter i was curious if that was worth $120 or is there alot cheaper options?
thanks
Old 05-13-2017, 03:22 PM
Roadie13's Avatar
Roadie13
Roadie13 is offline
Received 1,193 Likes on 563 Posts
Can buy a bluetooth transmitter/receiver from amazon for $30 bucks for a good one, less for a cheapo. It plugs into the aux port and you pair your phone with it. Very small and easily velcroed to the fairing. I used one for a season, held a charge all day and never had a problem with it, worked great. Don't need it after I traded my bike, if you want to try it PM me your address and it's yours for free.
Iron Cross will update your radio, but pricey.
nobodyknowsme (05-14-2017)
Old 05-13-2017, 03:32 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,609 Likes on 2,727 Posts
Old 05-13-2017, 04:10 PM
electra_boogaloo's Avatar
electra_boogaloo
electra_boogaloo is offline
agreed, i done this for a long time. very practical.
Old 05-13-2017, 04:27 PM
dandrumheller's Avatar
dandrumheller
dandrumheller is offline
I agree with these guys - if you definitely need BT, then plugging BT receiver into aux port is the cheapest easiest way.
If you're looking to use an alternate audio source (phone, ipod, etc) but don't necessarily need BT per se, you can get an FM transmitter that plugs into the device, and tune your radio to the matching FM station. I've used these in the past with mixed results in cars - never actually tried on bike.
My bike has the HD iPod kit installed (thanks to the previous owner) so I use an iPod dock BT receiver - plugs into the 30-pin ipod plug in the saddlebag, and I transmit to it from my phone mounted on the fairing. This doesn't need anything plugged into the aux port, so looks a little cleaner - but definitely not a 'cheap' way to go unless you already have the iPod dock kit. I actually could use a replacement cable for mine - but I haven't seen a cheap takeoff kit around anywhere....
Old 05-13-2017, 07:31 PM
Hate Work's Avatar
Hate Work
Hate Work is offline
You can buy a Bluetooth Rx/Tx that plugs into the AUX port. It will need to be recharged as you use it. I paid about $80 I think for one that mounts inside the fairing. It sill has to use the AUX port but I don't have to charge anything as it ties into any 12V source. Good luck on your hunt......
Old 05-13-2017, 07:59 PM
DigitalDave's Avatar
DigitalDave
DigitalDave is offline
Old 05-13-2017, 10:17 PM
tfi racing's Avatar
tfi racing
tfi racing is offline
Can't get cheaper than this,here's a great offer from obviously a good guy!
I use a cheapo blackweb adapter from Wal Mart,short cable and velcro'd to the bars,cheap,simple and works.
Old 05-13-2017, 10:55 PM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
when I had my old ride, I bought a cheap BT reciever on amazon and added an input to the radio and wired it out the rear. added a cigarette lighter under the fairing so It would charge while riding. worked great, except if you didn't ride for a few days. it would lose its charge since you had to pull the fairing off to hit the off switch. Ended up keeping the wiring under the fairing and moving it to my shield bag so i could turn it off when not in use.
It worked well for me.
Old 05-14-2017, 02:48 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Received 4,094 Likes on 3,494 Posts
thanks
This is the one I use. It works great & will hook up 2 helmets, Zumo GPS to radio via 7 pin cable to plug.
http://www.ebay.com/itm/Sena-Technol...NXF~Ww&vxp=mtr
Quick Reply: Cheapest easiest way to make stock radio Bluetooth?
