Any suggestions or experience with this issue
Got a question for everybody out there to see if they have any experience with this.
Here is the set up I have installed on the bike:
PN 69461-06B RTB module
PN 69200042A Tour Pak Running light/brake kit
PN 69200441 Auxillary light module.
I purchased the HD 12V tour pak power port kit to get that extra charging port for long hauls. Installed it per the instructions to the auxillary switch plug because I didn't want it powered unless the switch is on.
WELL, I went to test everything and the power port has power running to it with the switch off.
I think it has something to do with the auxillary light module. When I installed that initially, my passing lamps flash when the alarm activates. Did some searching on the forum and found that a lot of people have experienced that. Not to mention when the ignition switch is in the aux position the brake lights stay on. Researched that too and people have had that same issue.
How could the passing light module affect the aux switch because I left the charging plug, which has an indicator light on it in the port, and after I turned the ignition off it flashed with the alarm. I don't understand how the port can have power if the aux switch is off.
Any ideas?
Any ideas?
Sarah Nigh-Royal
07-05-2017 06:49 PM
