Tri lights
Tri lights
I have a 2015 Rushmore Roadhouse special, purchased part number 59600008, tri light for the rear fender.
This is fitted to USA models but not on bikes in the UK.
Fits great and the LED,s are good, but ........the rear turn signal/brake/stop lights don't work.
I have taken it off for now.
Can anyone explain why the it does not seem compatible with the UK models.
Cheers
Cheers
that is an original tri bar light as far as I know the only function they have is as a
running light
they don't have brake/signal function..
some aftermarket are available notably Custom Dynamics which has running/brake
which is what I installed
and then many Chinese manufacturers have a running brake signal they sell which require you to make up your own harness connections
personally I have not seen any that have all 3 functions that are a plug and play
running light
The OEM Tri Bar light is only a running light.
HD does have an upgraded Tri Bar light in the parts/accessories catalog that does have the brake light option. They won't have a turn signal option on that light though, as it sits right in the middle of the fender.
Part Number 67774-10
https://www.harley-davidson.com/stor...-light-upgrade
I added one of them to my previous Street Glide.
It is a plug in play part, remove the old one plug in the new one.
Your bike being an international model though, I am not sure if it would work the same.
But if the one you purchased works as a running light, the upgraded one will very likely add the brake light option as well.
Thanks for the reply guys.
I may not have made myself clear, the Tri light part i purchased replaced the blank one fitted in the uk.
IT works fine as a extra tail light but the turn signal indicators on my bike will not function, not the tri light.
I understand i have a international model, but are you suggesting Harley have different wiring looms on the Rushmore Roadglide models.
Cheers
Cheers
Cheers
Cheers
WOW so you installed the tri bar and the signals quit working??
as mentioned you need to look at wiring diagram fro both USA and UK models and see what differences are
I think it might be because the circuit board in the TriBar light isn't compatible with your bike. Is the TriBar a UK or US part? I'd also check the FSM for wiring clarification. The rear lights work through the tribar lights as it is part of the rear light circuit. I tapped into mine to get my tourpack lights to work the way I wanted them to.
Your UK bike is probably the same as my Canadian bike.As a previous poster stated,the non functioning tribar light is just a feed through to operate your tail light and signals.The wiring on the output side of the US light is totally different from ours.I believe that Custom Dynamics now makes a light that is compatible with our rides.
Randy Oblong
2014-2023 Touring Models
16
06-01-2018 01:41 PM
