Speedo Sensor
Speedo Sensor
Ok, so I had issues with the signals not auto canceling and the speedo needle jumping around, and eventually just stopped working all together. I pulled the sensor and cleaned the fuzzies off of it, it helped for a couple hundred miles then crapped out again. So, while I ordered a new set of keys for my bike (see what did you do to your bagger today to find that the original keys are up on the Blue Ridge Parkway somewhere.. gah), I picked up a speedo sensor and replaced it yesterday. I did notice that the old sensor was extremely "magnetic" and actually stuck on the pipes as I was trying to figure out how to get the wires around the starter. I'm assuming that this is what happens, the sensor gets "magnetized" and just stops picking up the gearing? I wonder if there would be a way to "de-magnetize" it if that's the case.... has anyone tried?
Yes, I'm aware that it's a fairly simple replacement part, however I'm just a curious soul with an electrical background.....
the pickup uses a magnet, just like a guitar pickup or the sensor on a car distributor ( some- post breaker points).
Could be your replacement version uses a weaker magnet ( less gauss)
never had one fail ( only have the 1 on my 09, rest have been cable drive)
Mike
Mike
It seems that the new sensor didn't have as strong magnetic attraction as the old one did, so this is what got my curiosity up...
Yes, I have changed the transmission fluid recently and it looked pretty good and clean. I guess the "fuzz" around the sensor has been there for a while...
Thanks for the responses.
