Fullsac DX pipe
When I installed mine, heat went down and performance went up. Maybe the best the single best improvement from anything I've done to this bike. I bought it used a few years ago. I did bend the pipe and break the brazed in o2 bung lose trying to remove a o2 sensor. Also the rear 6" of the header did break off. Both have been repaired and it is still working fine.
Blackflame, Yes, as long as it's not a M8.
I have ran a Fullsac "B" and "D" X-Pipe for 8 years.
BEST BANG for the buck, proven performance, proven reduction in heat, best fit using stock head shields, made in USA, GREAT customer support, forum discount.
IF, you can find some CVO mufflers, order Fullsac CVO baffles, Fullsac screens and TTS Mastertune Turner, ALL from Steve @ Fullsac. One stop shopping and Maps for life. This set up works period, and is pretty inexpensive compared to other "off the shelf" exhaust systems.
JMHO!
YB
JMHO!
YB
Yes, I replaced the stock '09 non-cat header with the Fullsac. The stock header ran so hot I could not keep my right foot on the board. Now it is a non-issue. No other change than the header.
Kburgad (05-09-2017)
JMHO!
YB
JMHO!
YB
