2016 FLTRXS Wheel Issues
I'm installing my new wheel tonight and I dunno if I'm just tired or stupid, but something isn't going right here. The rotor on the left side of the scoot is closer to the lower fork slider than the right side. I have the spacer on the right side, grooves out and the ABS module on the left side. Is the wheel on backwards? If that's the case, then the tire was mounted backwards...which I have a hard time believing because it was marked which side was left and which was right. Any thoughts?
Right side has more space between the rotor and fork slider.
Left side has less space between the rotor and fork slider.
Yeah, you can see the gap in the picture of the right side. There's 1/8" of play that I can slide the wheel back and forth between the forks. I threw the stock wheel back on and it does not have any play whatsoever. I'm not sure the answer is to push/pinch the fork slider in. I believe it's a hub or bearing issue
ShiftyCapone (05-12-2017)
No, I did not... That is exactly the issue. I realized it after swapping back to the stock wheel and noticing that the ABS bearing was a different color and wasn't as far recessed into the hub as the two identical ones installed on the new wheel.
