12 Electra Glide Classic, witch rear shocks and why?
Sasquatch2727 (11-26-2020)
Ohlins. Don't have and others than stock to compare it to. Night and day. But the ride is awesome. Pricey but awesome. There are a lots more but the ones on the forums talked about the most are. Ohlins MotorCycle Metal, Progressive 944's and Legends. I would think in most cases your wallet will lead you to some degree. Good luck..
I asked because it makes a difference. When riding solo most of us will be pretty happy with many of the shocks out there, however when riding 2-up, our favourite passenger gets a different experience back there, sitting directly over the rear wheel. It is worth going to the extra expense of good quality shocks so that Mrs M is really comfy and enjoys the ride too!
Local shops will only suggest what they have available. You're in a forum here, where all this research has been done and dusted countless times and we have looked far further afield than the local shops. I live in the UK and bought my shocks from Florida! If you fork out big bucks on say Ohlins you won't be disappointed and Mrs M will be absolutely thrilled! Be bold.....
If your willing to spend $750 plus the Ohlins and the like will all serve you very well. Keep in mind with those there's a million different settings for sag and damping you'll have to fiddle with to get them dialed in.
Try to find a set of used 13" HD hand adjustables. Adjustments are easy. Should be able to score a set for $300.
I hated the progressives had several sets. Different models & spring combinations. All rode like a truck.
