Cruise Control
Old 05-04-2017 | 02:41 PM
Lunchboxx's Avatar
Lunchboxx
Default Cruise Control
2001 Road Glide TC88
When I set my cruise control the green C come on in the gauge but when I let off the throttle it does not stay set. Any ideas on what I should check
Old 05-04-2017 | 02:48 PM
jimmything's Avatar
jimmything
I've heard the front brake may be stuck. There's a button that the brake lever contacts. Make sure it's not askew. And look at your brake light and see if it's on. Cruise won't engage if the brake is on
Rob175's Avatar
Rob175
....and you don't touch the clutch?...or shift?...or roll off the throttle......or touch the brake? (all of which will cancel the cruise control)
Old 05-04-2017 | 02:50 PM
sailmotion's Avatar
sailmotion
Not sure about the 2001 models, but if you "let off" the throttle by rolling it forward, that is one of several methods to disengage cruise control [others being, apply brake, engage clutch].
Old 05-04-2017 | 03:03 PM
coach127's Avatar
coach127
I had an 06 Ultra that did this each time they replaced the unit. This happen twice under warranty and it was out when I traded for a 17.
Old 05-04-2017 | 03:29 PM
Veekness's Avatar
Veekness
Simple deal. Find the idle cable which is on the right side of the neck, just ahead of the tank. Disconnect it. If the problem goes away, you've found the problem.
Two ways to handle. Either futz with the idle cable adjustment until it's fixed. Or do it my way. Leave the cable connectors unplugged. Whatever way you're more comfy with.
Old 05-04-2017 | 04:16 PM
gwaligorski's Avatar
gwaligorski
I had this happening on my 07 Ultra. I had did the Front Brake Master Cylinder rebuild. Super quick and easy. I have not had this problem again. My guess is that the spring in yours is now weak and will not hold the brake handle away properly. Quick test. While riding. Hold the front break lever out with your fingers and set your cruise control. Check the rear brake the same way just to make sure. If it stays on rebuild.
Old 05-04-2017 | 04:25 PM
cookie_62's Avatar
cookie_62
My 07 RK did that and it was the rear brake light switch.
Old 05-04-2017 | 07:10 PM
Tarkus60's Avatar
Tarkus60
Veteran: Marine Corp
My 02 does that also....and I am still working on a fix.
So good luck bro!
Old 05-05-2017 | 12:07 AM
0ldhippie's Avatar
0ldhippie
Three things turn off cruise: front brake switch, rear brake switch, and roll off switch on idle cable. Disconnect each to find the problem. Then there is the handlebar switch itself? If it still doesn't work troubleshoot the module.
Quick Reply: Cruise Control
