Got a code
Got a code
Po562 I believe its a low voltage code. I havent had any trouble from the bike at all so naturally the warranty runs out and this starts happening. Couple months ago I had some more codes pop up. All dealt with voltage, I think maybe high voltage codes that time. Had a HD mechanic buddy look into it and he thought it was either the stator or the rectifier. He tested the stator and it was good. So I ordered a rectifier off amazon (it had all positive reviews I swear) Anyways put it on and it blowed the main fuse. Put the old rectifier back on and a new fuse. still throwing this code. The bike runs fine other than the very first time it throwed a code, it shut my cruise off for a second. Couple of weeks ago, My buddy put it on the computer at the dealer. It showed no current codes or historical codes. I know damn well it had tripped codes. Im guessing its a loose wire or connection somewhere. Anybody run across a similar issue? Looking for ideas here.
my voltage regulator started going bad, fine, low voltage, and would repeat. got new regulator from a shop. installed it then to much voltage. took it back ordered from internet and installed everything is back to normal. did not from dealer because they do not take back if its bad unless they install it. don't know if its the same problem. just some more info to use. good luck.
kroozeabout.
kroozeabout.
Mr. Sawyer, generally, no returns on electrical parts is pretty much the case across the board. The reason is that over the years, people have taken the 'shotgun approach' with diagnosing problems...they buy an electrical part, try it, isn't the problem, then they want to return it for a refund or trade for another part they suspect might be the problem.
Mmmm...nope.
And I'm not talking just DIY guys either...this was often the case with experienced 'mechanics'...
Mmmm...nope.
The standard "wisdom" for intermittent electrical stuff is to check battery connections tight and clean, same with the opposite ends of the same wires. If that doesn't help, then the trouble shooting begins. I have had excellent results with a Cycle Electric replacement voltage regulator. Should you wind up needing a new voltage regulator, at least check them out.
Why "get lucky" why not TEST the charging system and find out WHAT part has failed? The tests are very simple, take 5 minutes and are in the service manual!
I had low voltage problems with my bike. It was covered under the 2012 voltage regulator recall. That replacement regulator last 1 year. I upgraded to the high output alternator from HD and still had low voltage problems. What I finally found was that the dirty ground was not making a good connection back to the battery. On my particular bike 2012 FLHTK there are 2 ground studs in front of the battery. The clean ground is on the right and the dirty ground is on the left. The clean ground has a direct path to the battery and the dirty ground doesn't. If you look at the wiring diagram the voltage regulator grounds to the dirty ground. What I did was I ran a wire directly from the dirty ground to the negative post of the battery. Problem solved. I hope this helps.
http://blog.jpcycles.com/step-by-ste...arging-system/
Completely a financial decision and a need to ride. It worked. Simple as that. Could not afford anything over and above the regulator at the time.
dirtdobber
Screamin Eagle CVO Models
04-25-2015 08:00 PM
