Stock Road King handlebars
Old 05-04-2017, 02:55 PM
Tracker1's Avatar
Tracker1
Tracker1 is offline
For my 01 RK I had the same issues, too wide and had to reach too far. The dealer had a set that were a little narrower, a little taller, and a little more pull back without having to change the cables. That worked out great. They were called Tall Boy bars that were 3.5" taller and 1.5 narrower.
Old 05-06-2017, 10:16 PM
grubsie's Avatar
grubsie
grubsie is offline
OK, I got the Khrome Werks Heritage bars and not happy with them except for width (still leaning forward). I did however figure out what I am looking for as far as bars go.
The standard stock height is perfect. the width a little narrower and the way they angle to the side like the Heritage bars is good too. But they need to come back to me more like 3-4". Preferably 4"
I like to sit upright or a little leaning back with my arms slightly bent when I ride. At this point, I would be happy sitting upright with my arms stretched out. Not really though.
Know this is a tall order, but is there anybody that is 5'-8" like me and found a solution like I am looking for with their bars?
Maybe Harley's own Tall Boy?
https://www.harley-davidson.com/stor...high-handlebar
Old 05-07-2017, 01:58 AM
Tarkus60's Avatar
Tarkus60
Tarkus60 is offline
Yea the second post of this thread.....
Old 05-07-2017, 10:06 AM
grubsie's Avatar
grubsie
grubsie is offline
Thanks for that. I saw apes in the beginning of the post and skimmed over it the first time so I missed the link.
Just ordered the Tall Boys
Old 05-12-2017, 10:41 PM
grubsie's Avatar
grubsie
grubsie is offline
Got the Tall Boy bars today and changed them out. What a difference! It's like a whole new bike. I could ride this setup all day without any discomfort.
Anyway, a few things. First was even though the bars were clamped as far as they could be clamped, if I pulled up or pushed down hard enough on the bars, they would move. Upon closer inspection, I noticed that the top clamps were touching the lower clamps and couln't be tightened any further. I removed the top clamps, one at a time, and and ground almost 1/8" off them. Re-tightened each clamp and they hold perfectly. I could whack the handlebars with a baseball bat and they wouldn't move.
Which brings me to my second issue. Once i buttoned everything back up, it looked like the bars were crooked. What I figured out was if I forcefully turned the bars as hard as I could left or right, the bars would go crooked in whatever direction I turned. I tightened the nuts for the lower clamps that are under the top triple tree and it's holding much better but can still go crooked if i push/turn hard enough.
Is there some kind of shim/spacer that I need to hold the lower handlebar clamps from being able to move? Are the rubber mounts in need of replacement? Where do I go from Here?
Old 05-13-2017, 03:26 AM
Tarkus60's Avatar
Tarkus60
Tarkus60 is offline
Yes replace the rubber mounts also maybe go with a 1 piece mount. I did both and it helped. They are still a tad off, but much better.
http://www.jpcycles.com/product/500-014
Old 05-13-2017, 07:02 AM
Tracker1's Avatar
Tracker1
Tracker1 is offline
Mine did the same thing so I just made sure everything is adjusted right and left them be. I pulled on mine to get them even and the have stayed that way. I have to turn hard against full lock to get them out of alignment.
Old 05-13-2017, 08:25 AM
psause's Avatar
psause
psause is offline
Default Stock bars
I have a 2012 Road King. Changed to a 2014 Road King stock bars. Big difference. Should have done it years ago.
sel53
11-15-2013 07:07 AM
HDRoadking_nc
08-31-2012 09:40 PM
HunterBLT
07-31-2011 05:14 AM
DGlide04
09-16-2008 08:16 AM
kemp427
03-13-2007 01:13 AM
Quick Reply: Stock Road King handlebars
