Visor Style Trim Rings 2013 FLHRC
I've decided to add some additional accessories to reinforce the nostalgic look of my 2013 Road King Classic, and finding some accessories are no longer available from the dealer since the US RKC was discontinued in its prior version. Ordered saddlebad trim for the leather bags from e bay and some various visor style trim rings for the lighting from Harley but running into some questions and still unclear after reading many prior posts on the topic of visor style trim rings for headlamp, driving lights and turn signals.
I bough the visor trim for the front driving lights and the standard non led headlamp. Got the driving light trim rings installed though it seemed far more difficult and time consuming than I anticipated, mainly due to the tight fit created by the added rubber ring.
More concerned about properly installing the headlamp ring as many threads indicate people cant get it to attach without modification, and many others have a gap at the junction. My read is it fits over the existing trim ring, rather than replacing it. Am I interpreting that properly? And why would some need to add 6-7 flat washers for a secure fit, or could that be a matter of using the wrong part?
I had not initially considered the turn signal trim rings but I notice they are still available for the front turn signals. The part is 69749-05. The description mentions a smoked lense cover, but none of the other trim rings replace the bulb lense/housing. Is this an error? Not sure why a lense cover would be needed or that I want to change the color of the front or rear turn signals to smoke. Or if this even fits the rear turn signals.
Appreciate any input from others who have been down this road.
The gap doesn't bother me, as long as it mounts securely.
Did find 2 different part numbers for visor style turn signals on my bike, one set is closer to $20 and the other is in the $45 range so might have to visit the dealer to see what is different on those. Both list 2013 RKC under fitment.
I didn't like the gap so I took off the stock headlight ring and added a thin layer of double sided foam tape to the headlight mounting cup and wrapped it around the perimeter. Then I opened the visor ring up slightly to fit it over the tape and closed the gap. As soon as it touched the foam tape it wanted to stick so I had to be careful and center the gap before putting the screw through the eyelets. The result is a tight gap and the visor is mounted securely.
No, just a little effort and I can't see needing to replace the bulb too many times unless these bikes go through them like crazy. You could just leave one side with the back still on like you were thinking. The main thing is it just needs to take up a small gap so the ring is tight. Without the tape the ring isn't flopping around but its not as tight as it should be. Leaving the OEM ring under it seems like a banana move on HD's part for such a design. The signals don't need the stock rings so why the difference?
