Throttle By Wire, do I have it?
Old 04-20-2017 | 12:50 PM
vizcarmb's Avatar
vizcarmb
The easiest way to know if you have TBW is to remove the throttle or check if there are cables hanging out near the throttle. A visual check is your best bet
Old 04-20-2017 | 05:20 PM
smitty901's Avatar
smitty901
Originally Posted by rickdwyer
Thank you all.
I will get the service manual. I am about to install new bars and grips, and need all the instruction I can get.
Yes you will. And do every bit of home work before you buy any parts. A lot of do it your self bar swaps end up in another thread . My xxxx does work , I fried xxx. Ect. It can be done but you need to be real sure what you are doing.
Good luck.
Old 04-20-2017 | 05:55 PM
Tedjay's Avatar
Tedjay
Here's a thread I found helpful when I installed new bars on my 2012 RK. He (dr_jay) provides photos and descriptions of the work as he installs the new bars. This and the service manual were invaluable to me.
https://www.hdforums.com/forum/touri...road-king.html
You'll find it's a long thread because people are commenting in between dr_jay's posts.
And +1 on getting the service manual.
Good luck with your bar swap.
Old 04-20-2017 | 06:00 PM
TSheff's Avatar
TSheff
Thank you all.
Service manual is a must.
Not meaning to sound too abrasive, but if you didn't see that you don't have throttle cables perhaps you should let someone else handle the modifications. Learning is great, throttle and brakes done wrong can get you killed.
Old 04-20-2017 | 08:21 PM
Trixter's Avatar
Trixter
Please listen to Tsheff.
Old 04-21-2017 | 02:52 PM
Joe12RK's Avatar
Joe12RK
Thank you all.
The manual will bounce you around quite a bit - follow along carefully. Many have broken the brake light switch by not following instructions.
Pierre
08-16-2016 10:42 AM
Woodys03
02-13-2015 05:52 PM
whitz
12-01-2012 07:58 AM
Po2387
03-26-2011 11:49 PM
Rick06
08-29-2009 02:15 PM
Quick Reply: Throttle By Wire, do I have it?
