no brake lights???
Old 04-14-2017, 01:10 PM
vicsponjr's Avatar
vicsponjr
vicsponjr is offline
Checked fuses,removed module and BAL light. Brake light works fine, turn signals work.
Still no running lights, and nothing to the tourpak lighting
Old 04-14-2017, 01:48 PM
vicsponjr's Avatar
vicsponjr
I may have found the problem. The blue wire on the 7 pin plug (7B) is only showing me about 1/2 volt. I guess I have to keep digging and see where it goes
Old 04-24-2017, 04:56 PM
vicsponjr's Avatar
vicsponjr
Wound up being the fuse
Old 04-24-2017, 05:34 PM
Veekness's Avatar
Veekness
Veekness is offline
Thanks for circling back...sometimes its the littlest things drives one to drink, huh?
Old 04-26-2017, 08:48 AM
vicsponjr's Avatar
vicsponjr
yeah, i checked the fuse with the volt meter and it was good. i was about to start pulling the harness out but thought i should try replacing the fuse and it worked. go figure.
Lucky1359
02-20-2017 02:41 PM
Mr.Softy
06-21-2015 09:36 PM
ronbeejer
03-09-2014 08:20 PM
06SGWA
07-28-2013 12:42 AM
mblackmon
07-05-2009 10:37 AM
Quick Reply: no brake lights???
