cracked Tourpack
i would take a piece of 1/16" aluminum sheet, 3" x 14" and contact cement (super 77 maybe) it to the inside of the tour pack. tin snips to contour around the hinge if needed, drill the 2 lower rivets and put small chrome nuts and bolts in a line down the 14" and the 4 lower rivet holes. This will hold it together for a long time.
Get a pastic epoxy, Loctite and JB weld make one, among others.
Take a dremel and create a "V" along the crack, use a coarse grit sandpaper to roughen it up, then denatured alcohol, starter fluid on a rag, etc., something that will clean the dust but leave the surface dry as a bone. Obviously, careful around painted parts.
Prep and dry/bonding time are everything.
Had a crack at my hinge on my tour pack. Too many hard opens slamming it against the cable, lesson learned.
Here's pics of mine. Is it body shop quality clean and gorgeous? no. Absolutely not. But My bike is ridden and has it's share of nicks, scratches, etc., the crack hasn't spread a millimeter since the repair. I hit it with a bit of touch up paint...
Looking at the previous post reminds me that you can drill out those rivets to give you a better shot at the repair, then use screws or source the OEM rivets from HD to reattach when you're done, if that's appropriate for your repair, OP. Good job on that repair, dajogejr! Ya got the job done, and it's a WHOLE lot better than spending a grand on a new box!
If you have the skills and equipment, you can drill and tap holes for the hinge attachment screws into the metal brace for a cleaner inside appearance. Be cognizant that you may have some clearance issues with the screw heads, which can be mitigated by using different design screws, like panhead screws, or simply grinding down the screw heads until the hinge closes like it should.
Fiberglass will still adhere to ABS with proper prep, and will reinforce/repair the crack. Do it inside, then file and fill the outside n paint. Not a body man, but pretty sure that would work fine.
Yep. Just so. Have done it several times my own self with excellent results.
epittman15
General Topics/Tech Tips
09-30-2010 11:29 AM
