New Rineharts installed!
My new Ultra now has a new exhaust system. The removal of the stock system was a pain!! The new Rineharts went on pretty easy, but are louder than I expected. At least it sounds like a Harley now! Time will tell if I can stand it or if I need the quiet baffles. Is anyone running them and do they make an appreciable difference??
RE: New Rineharts installed!
I just installed a set of Rinehart true duals on my 07 Ultra and they sound great. They are a lil on the loud side when you crank down on the throttle but they are not too bad as long as you use good throttle restraint. They are by far the best sounding, "in my opinion", true dual setup that I have heard.
And YES,.......... removing the stock header pipes was a real PITA,.........
John
John
I'm looking forward to giving it a good road test to really hear them, I was only able to take it around the block last night. Little nervous about riding it until Wednesday, I found a large pool of oil under the darn thing when I went out to start on the exhaust. Turned out to be a primary leak at the derby cover. Every bolt was loose (**** poor dealer prep??). I tightened them up but it's still leaking just a bit and I don't know how much I lost while riding (quite a bit based on the oil spray an everything!) So it's going in Wednesday morning, THEN I'll get to take it out and really hear these pipes.
I also installed a set of Rineharts last weekend. I agree taking stocksystem off was tougher than putting the new on.
After the install, I fired it up, and I felt the same way. I thought they sounded extremely loud. After running the stock pipes for 7500 miles, anything will sound loud. But you'll get used to it real quick. Just give it some time. You'll love it!
I find I turn the radioDOWN now, just so I can hear the exhaust. The music coming out of those pipes is better than anything coming out of the speakers!
Stro,
Did you change your air intake as well? I'm assuming that you also did a Stage I air intake upgrade? This is a must if you're changing the exhaust system. Just a thought.
Kahuna
Kahuna
ORIGINAL: stro1965
