Slight Ping after Stage 1
So I put a set of pipes v&h pro pipe, intake, and power commander v on my bike over the weekend with a map by fuel moto. Took it for a few short 5-10 miles rides and it rode and sounded excellent. Today I took it for a good 200 mile spin and noticed a ping or slight crack sound once it warmed up. This only happens when I am cruising at 2500-3000 and hammer it hard. It sounds like a ping or crack and only last a fraction of a second but it is definetly there. Also noticed a couple decel pops when coming off the throttle which I hoped I would not hear with the fuel moto map. Fuel moto says it's a proven map for my set up. Any ides what it could be? Bike is a 2012 street glide with only the above mods. It seems do do fine if I roll on the throttle easy if that makes any difference.
If so, you need to downshift.....
Best tune in the world can't help when you ask the engine for more than it has...
Good question but to answer no. It doesn't matter what gear I'm in that's just the sweet spot where it happens most. actually it does it if I'm at 3500 also. Never did it until I put the pipes and power commander on. Possible exhaust leak? I stuck a candle by the intake and goosed it to see if I could see the flame flicker and nothino. My guts telling my its a leak though.
Does the Power Commander V allow you to datalog? If so, I'd run a good datalog, session, including conditions that cause the issue, and send it to FuelMoto to examine...
At the very least you could send back the tune, with notations on what it's doing and when (rpms). FuelMoto maybe able to tweak it for you...
Good luck...
Lotaluck (04-09-2017)
Received 4,815 Likes
Received 2,530 Likes
Good to know. I got fuel moto working on a new map and will report back. I was hesitant to mention my fear of an exhaust leak because I wanted open minded opinions and didn't want to start the conversation to exhaust leak only. Sure hope it's the map, don't feel like screwing around with the exhaust.
