Fender Tail light 2014 Street Glide
Hey OP, Welcome to the forums.
I see your location is listed as NF Canada. That will be why the light doesn't work, because there are none. Canadian spec SG's have only the lenses, but no lights inside. Something to do with TC regulations and the light being too low. You'll also notice that US spec SG's do not have the fender tail light, just the tri-light at the fender tip, whereas yours will have the tail light above the signal light bar. It's wired completely differently than the US spec bikes, and require some ingenuity to get working.
If you take a look at your tri-light, you'll see there are two plugs on either side of if, so it does receive power. When I opened up the lens box on mine, all that was in there was a chip board that went straight through to the other plug, basically connecting the two plugs together with nothing powered in-between.
As I understand it, you cannot just buy a US spec tri-light and plug it in for it to work, because on the US spec bikes the brake and signal lights act differently than the Canadian spec ones. The only way I know how to make it work is by opening up the case and soldering in the innards of a tri-light onto the chip board. The below item is similar to what I spliced in to make it work.
https://www.revzilla.com/motorcycle/...ring-2014-2017
Just be careful with that chip board if you choose to go this route.
Hey Paul, I just got a 2017 Street Glide Special (Canadian Model) and the tri-light housing is empty. What I did: I bought a light on EBay from China (took 2-3 weeks $36). I took the one off the bike cut out all the little plastic ***** inside and took apart the one from China and stuck it inside (silicone it up and let it sit over night) I then put pins on the wires and stuck them in the proper spots (very easy) then greased up the plugs (dielectric grease). it now works as a running light, brake light, turn signal and 4 ways........so CUUUL........good luck
http://www.ebay.com/itm/Smoke-Tri-Ba...JYEFQS&vxp=mtr
