2013 Road Glide Ultra all gauges dead.
Old 04-06-2017 | 06:34 PM
Hanstone1's Avatar
Hanstone1
Stage I
Default 2013 Road Glide Ultra all gauges dead.
at the first stop of many yesterday on the Scottsdale Harley Prostate Cancer ride I came out and got on the bike and started her up and NO Gauges. The lights on the speedo and tach work but not the gauges and the 4 small gauges are dead. The headlights work and the turn signals work as well. No lights on the 4 small gauges or the Neutral light. I changes the 15 amp fuse for accessories today but no help. The fuse was shot. Any ideas? Thanks all. It's bike week I am not a mechanic and all of the dealers are swamped. I was to go on the rides but not without gauges, Fuel Temp, Oil pres, air temp and especially speedo and tach. HELP!
Old 04-06-2017 | 07:34 PM
Vernal's Avatar
Vernal
Did you check all fuses? Battery fuse?
Did you look for codes?
https://dgcustomcycle.com/tech/harle...es-04-present/
Old 04-06-2017 | 07:47 PM
liquidr1's Avatar
liquidr1
you said the fuse was shot? was that the original fuse, or the new one you put in. If the new one blew right after you put it in, you have some wiring somewhere shorting out to ground.
Old 04-07-2017 | 06:59 AM
dyna rider's Avatar
dyna rider
Default Gauge Power
Sounds like you have a pinched wire in the handlebar controls. When were the bars changed or the hand controls opened ? I had a pinched wire for about a year but something else precipitated the short that took out most of the electrics.
Old 04-07-2017 | 07:38 AM
14GuineaPig's Avatar
14GuineaPig
Check all fuses, especially the Accessory, Battery, & Instruments fuses.
Old 04-07-2017 | 07:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Welcome to the forum on a not so good note. The instrument fuse would the next fuse to look at. What was the last thing done to the bike?
whitford000
04-17-2017 02:06 PM
Troystoys
08-16-2013 06:34 PM
mmitchell
02-09-2012 07:34 PM
goose136
12-15-2011 10:34 AM
Tbonefluffy
03-12-2009 09:50 PM
Quick Reply: 2013 Road Glide Ultra all gauges dead.
