Winter storage, what do you do?
Old 10-09-2005, 11:57 PM
Watkinst's Avatar
Watkinst
Watkinst is offline
Default RE: Winter storage, what do you do?
I recently received my September/October issue of Hog Tales magazine, and here is what they had to say on the subject...(article on page 30)
- Clean and dry all surfaces
- Wax painted surfaces
- Fill fuel tank and add gas storage additive
- Change oil and oil filter
- Clean and charge battery
- Check tire pressure
- Check electrical system
- Cover bike with breathable cover
The reason they give for the oil and filter change is to prevent acids and combustion byproducts from attacking engine parts. They further recommend to run the engine for a few minutes to drive out any moisture and to leave a fresh oil film inside your engine...Hope this helps.
[IMG]local://upfiles/4702/5F60825985A6459BAFDC283295D50B38.jpg[/IMG]
Old 10-10-2005, 01:45 AM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
good gloves face mask, keep on truckin!!
Old 10-13-2005, 06:17 PM
ScooterGuitar's Avatar
ScooterGuitar
ScooterGuitar is offline
gREAT INFO!
So, I don't have alift, I should put the wheels on wood blocks heh. Never knew that, sounds logical.
Old 10-13-2005, 11:07 PM
Peekaboo Bob's Avatar
Peekaboo Bob
Peekaboo Bob is offline
Winter? What's that?
Steve
Old 10-18-2005, 09:13 PM
Detour's Avatar
Detour
Detour is offline
ORIGINAL: UltraGeezerGlide
Steve
Man, you guys are brutal!!!
Kurt
Old 10-18-2005, 10:35 PM
Harley Rulz's Avatar
Harley Rulz
Harley Rulz is offline
No offense to anyone but,damn I'm glad I live in Texas.We don't have much of a winter so just ride on.Of course we think 50 deg is cold so go figure.
Old 10-21-2005, 09:15 PM
Snarly's Avatar
Snarly
Snarly is offline
ORIGINAL: mndemohead
The past couple of years I have put fuel stabalizer in the fuel, Topped the tank off with fresh fuel, changed oil, pull the battery and bring it in the house and thats it.
I do the same. I just make sure to put it in the living room, not the family room, too much traffic
in there.
Old 10-21-2005, 09:41 PM
JBBOOKS's Avatar
JBBOOKS
JBBOOKS is offline
I always change the oil in the fall. I will drain it out and add new (and filter) in the spring as well.
I use a regular 10W-40 for storage then drain it and refill with Mobil 1. Probably not needed but it makes me feel better.
Old 10-21-2005, 10:25 PM
Wally's Avatar
Wally
Wally is offline
Do you change all three oils or just the engine oil? The reason I'm asking is because when I put my bike into winter storage I'll probably have about 1,000 miles on the engine, transmission and primary oils.
Old 10-23-2005, 09:55 AM
JBBOOKS's Avatar
JBBOOKS
JBBOOKS is offline
I will do all three in the fall, then change the motor oil and filter again in the spring. I figure the motor oil has soaked up a lot of junk over the winter and it's cheap insurance to dump it.
The primary oil and tranny oil are OK to leave in until the next scheduled change, IMO.
Quick Reply: Winter storage, what do you do?
