Toggle switch on nacelle
I have an LED strip I want to put on the bike but it needs to be wired in and I am ignorant with electric stuff. Im wondering if I can hook it up to the toggle switch on the left side of my nacelle (09 Road King Classic). Is that switch already hooked in to a fuse? What do I need to do to hook these up?
It is the 15 amp acc fuse in the fuse box. The wire from that switch goes to a capped plug under the seat in front of the battery. There are 4 wires in that plug. Black is ground, orange is accessory(on with ignition on), orange with a red stripe is the switched accessory (the switch on your nacelle) and the red with a yellow stripe is a brake light wire. You can get the Deutsch plug from JP Cycles or from HD with wires already attached.
Find that plug and that's how you wire up your LEDs to work on the fork tin toggle.
For reference, I asked pretty much the same question years ago cause I wanted to run my spot lights off that switch. It works perfectly by the way.
