103ci with 110"SE heads. Yes or No?
I'm in the process of having my 2011 103ci FLHTP rebuilt. My setup is Arlen Ness St2 Big Sucker intake, Power Commander V with auto tune, S&S Power Tune Headers, V&H Oversized 450 duals. The guy doing my build suggested TW-408-44 Woods cam, S&S adjustable pushrods, porting my stock heads, and installing compression release.
They ordered the wrong cams for a build (TW-408-6), but while I was in the shop today he said it would be badass to do do these other high lift cams with a set of Screamin Eagle 110 heads, instead of our origional plan of just bolt in cams and head work.
I'm trying to keep cost in mind, but he said after subtracting the hours for head work and compression release, it would only be another 600 bucks for those heads, pistons, and to fix the flywheel. Thoughts??
The pragmatic approach is to disconnect the rockers and measure the volume inside the head at TDC then measure the volume of the head plus stroke at the bottom position. You can do this with a large graduated syringe using light engine oil to calculate the compression ratio. Next thing to do is to check piston clearance with "unknown" valves. I used moulding paste in the past and accepted a 1mm parallel gap with the piston
A lot would depend on which generation of the 110" heads your fella wants to use. The older 110" heads from the first runs of the SE motors are almost worthless as far as their reliability in a 103" motor goes. As mentioned above, wrong size valves, combustion chamber volume too large, and valve guide slippage are the first three things to consider.
I'd say the next step would be 110" cylinders. If you're gonna do all that, heads, crank, cams, etc, why not add a set of 110 cylinders and go all the way? That way you could, I think, take advantage of the head combustion chamber size
I see you mentioned pistons. He planning to bore your 103 cylinders?
