Considering Progressive 440's on Ultra
What will I give up in comfort and/or performance if I go with 12" or 12.5" instead of 13"?
Together we weigh 325# (185# + 140#) and ride loaded quite a bit....legroom isn't a problem, but I like the lowered look of shorter shocks
I don't want to compromise ride comfort and I don't want to bottom out while loaded...should I just stay with the 13" or will the shorter shocks work with our weight?
RE: Considering Progressive 440's on Ultra
ORIGINAL: kdietz
Together we weigh 325# and ride loaded quite a bit....legroom isn't a problem, but I like the lowered look of shorter shocks
Another option would be to buy a White Brothers (Burly Brand) or other lowering kit, which will lower your bike 1" using stock shocks. I had these on my '96 RK and they were faultless. Ride was fine and never had a problem with clearance. They claim you retain the stock suspension travel, which is a plus. And at about $125 is more economical than replacing the shocks.
Some claim Works Performance shocks are superior to the 440's, but my experience is that their customer service is lacking, and they claim that every 30-40k they need to be sent to CA for service at a cost of $85, plus shipping both ways. This put them out of contention for me, and after experiencing their rude customer-service personnel I wouldn't consider them again. Progressive has a lifetime guarantee on their shocks, and claim it isn't unusual for their shocks to last >100k in a street environment.
just a side note if you will call progressive they are happy to recommend length and spring stiffness. in my case I weigh 170 and my wife around 145 the tech I spoke to recomended if I wanted to go to 13" then the standered rate springs are what I needed
Best prices that I have found, not saying that this place is the cheapest, but these arethe lowest prices on 440'sI have found. If you need to check the numbers just go to progressives web site. I asked the seller a question and it took about 1.5 -2 days to get a answer, just so you know. If i go with the 440'sI'll get mine from him. http://search.stores.ebay.com/Motorc...673711QQsofpZ0
I have a set of 12 inch Works Performance shocks, their top of the line model.
The ride quality is BETTER than the stock HD air shocks that came on my '05 Ultra. The handling is imrpoved and wallowing in corners is GONE.
I intended to get a set of Progressive 440's, but got a deal on these (half price) and couldn't resist.
They are going on my new bike, an '07 FLHTC
Karl,
Before you go out and get a set of the 440's take and consider an alternative...
BITUBO Italian racing rear shocks
There comming to the H-D touring world
Heres a little I managed to pick up...
Spring Preload (not just 5 clicks either), Rebound Damping (5 adjustment points), and Compression Damping (several click settings from hard to soft) through a separate nitrogen filled reservoir attached to the shock.These shocks can be fine tuned for your riding style and load.
These shocks are completely rebuildable, and Traxxion will service them if/when that ever becomes necessary. A kit is available for doing so. The Traxxion customer service is excellent, and they will stand behind their products with both service and tech support.
they are having some positive reviews on another forum...
patience Grasshopper
ST8cruzin
12-31-2015 04:41 PM
