Front turn signals won't blink or work with flasher
Old 03-26-2017 | 09:42 PM
C908's Avatar
C908
Default Front turn signals won't blink or work with flasher
Just noticed my front signals are lit but won't flash when the turn signals are on. I also checked the four way flashers and the rear work but the front don't. I just changed out all the bulbs when I added smoked lenses a few days ago. I installed 1157's in the front and 1156's in the rear. I applied dialectic grease on all four bulbs. Any idea what the problem could be ? Thanks.
Old 03-26-2017 | 09:48 PM
gusotto's Avatar
gusotto
Year and model?
You might try putting the old bulbs back in and see if they will flash.
If they do, then slowly add the new bulbs.
See what happens.
Old 03-26-2017 | 10:16 PM
OkieBill's Avatar
OkieBill
Pull the front and place the old bulbs back in and try again. Single-filament bulbs like the 1156's have caused many headaches. Ran into this same issue last year.
Old 03-26-2017 | 10:21 PM
GregGillette's Avatar
GregGillette
I think the 1157s should only be installed one way, has a high and low side nub but Ive seen installed incorrectly on cars and cause this.
Old 03-26-2017 | 10:22 PM
OkieBill's Avatar
OkieBill
Stupid keyboard! Front are the dual-filament 1157's - they may have one filament bad causing your problems.
Old 03-26-2017 | 10:24 PM
C908's Avatar
C908
Found the problem, to much dialectic grease. I was tired the other day when I changed out the bulbs and evidently went to heavy with the dialectic grease. I pulled them to test my old bulbs and immediately noticed the excess grease. Tested the old bulbs and they worked fine. Wiped the new bulbs down a little bit reinstalled and all is good. Thanks for your comments.
Old 03-29-2017 | 10:42 AM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
I was just getting ready to say that, too much dialectic grease can case more problems than does good. Glad you found the problem my friend.
__________________
LONG RIDE SHIELDS
www.longrideshields.com
C908 (03-30-2017)
Old 03-30-2017 | 08:17 AM
C908's Avatar
C908
Thanks and I'm still enjoying my Long Ride Shield.
Old 03-30-2017 | 11:55 AM
ORradtech's Avatar
ORradtech
Yep, dielectric grease is an insulator. It's meant to seal, lubricate and insulate against stray or high voltage leakage. You can put a thin film oc contacts because the physical connections are enough to brake the film and allow conductivity. Too much and yoy won't break through the film.
cprhed
07-22-2016 05:19 AM
PCKLST
Electrical/Lighting/Alarm
08-08-2012 04:03 PM
vabubba
06-05-2007 07:37 PM
suntz
08-07-2006 04:00 PM
bass2
03-15-2006 03:18 AM
