The All things ROAD KING SPECIAL THREAD
Old 07-27-2017, 04:08 PM
Spookyfishlizard's Avatar
Spookyfishlizard
Spookyfishlizard is offline
Stage III
Originally Posted by Spookyfishlizard
-Stage II
-D & D exhaust
-HD Heavy Breather
-Curved License Plate
-Kuryakyn LED Signal Bulbs
-Daymaker Headlight
-Shifter Linkage
-Inner Primary Cover
-Oil Cooler Cover
-Plugz LED in antenna holes
-Black Brake inserts
-Black front Hub Covers
-Windsplitter windshield
-Defiance foot boards, hand grips
-Reflector removal from saddle bags
-Fork lock cover
Kuryakyn LED Bulbs, white running. Daymaker Headlight
Kuryakyn LED bulbs, white running, amber turn signal.
Thought I could live with the chrome windshield brackets...I was wrong. Back from powder coating.
Windshield Brackets Powder Coated
  #452
Old 07-29-2017, 06:22 AM
FunnelCake Combo's Avatar
FunnelCake Combo
FunnelCake Combo is offline
Here is a quick take off and ride by on my RKS
Stage 1.
Rinehart Slimline Duals, 4" Slipons, S/E Ventilator and PV Tune
6113_ (09-12-2017)
  #453
Old 07-29-2017, 06:49 AM
Roadrage1996's Avatar
Roadrage1996
Roadrage1996 is offline
Stage 1.
https://youtu.be/HNNNIyLYOVw
sounds very nice...
  #454
Old 07-29-2017, 09:55 AM
JPGA's Avatar
JPGA
JPGA is offline
Hi from Switzerland, here it comes 2 & 1/2 months later. Pick up planned next week. Jp
  #455
Old 07-29-2017, 02:02 PM
RgrBoy's Avatar
RgrBoy
RgrBoy is offline
Stage IV
Default KST 14" Outlaws on the RKS
Hey Y'all. Really loving the KST 14" Outlaws. Much more comfort for me in my neck and shoulders (6'3", long arms, 225 lbs). Grips (Harley Magnum) right at shoulder level. I do run my bars a bit forward because of my long reach which also raised the grip level slightly. I will tell you all that the short part of the wiring harness on each side got a six inch extension. Did the soldering and shrink tubing myself, easy enough no need for a kit. I absolutely received NO joy from having to pull the wires through these bars, especially on the throttle side! It was tough going!! Clutch and brake lines had plenty of length and fit quite nicely with these bars. Love the way the bars ride for comfort, looks, and handling. Oh yeah, new riser bushings of course! Looking forward to The Forge LLC finishing up my twisted steel 18" sissy bar (pics after install). 1000 miles service at the dealer in three days and then I'm done with those folks touching my bike! Hopefully no warranty work will be needed. Loving this RKS!!
6113_ (09-12-2017)
  #456
Old 07-31-2017, 11:47 AM
jamesf0622's Avatar
jamesf0622
jamesf0622 is offline
That looks real nice. I'm planning on adding the windsplitter windshield to mine. Looks even better with black brackets. Would the windsplitter fit with the brackets for the aux lights installed?
Attached Thumbnails The All things ROAD KING SPECIAL THREAD-brackets-1.png   The All things ROAD KING SPECIAL THREAD-brackets-2.png
T-Strap (08-02-2017)
  #457
Old 07-31-2017, 02:16 PM
Brewtality's Avatar
Brewtality
Brewtality is offline
New bars and a few other changes. Loving the way it has come together. Doubt I'll change much else until winter.
  #458
Old 08-01-2017, 06:16 AM
Poodie's Avatar
Poodie
Poodie is offline
Default We
Originally Posted by Brewtality
Congrats and welcome!
You keep the '14 CVO or trade it in?
welcome
hope to get mine in a few days😊
  #459
Old 08-01-2017, 07:28 AM
LN Nation's Avatar
LN Nation
LN Nation is offline
The answer is "yes." I relocated the front turn signals using the Bullet Front Turn Signal Kit p/n 67800167, which mounts the same way the aux lights mount. Just be sure to purchase the windshield mounting hardware kit. The only down-side is that you will have a black wire exposed on each side. I chose to run the wires toward the back of the forks and then inside the nacelle. The windshield brackets will be hidden behind the aux lights. It would probably be a waste of time and money to have them painted, since they will be out of sight.
6113_ (09-12-2017)
  #460
Old 08-01-2017, 07:40 AM
LN Nation's Avatar
LN Nation
How did you run the wires from your front signals? They don't look like they're exposed.
Quick Reply: The All things ROAD KING SPECIAL THREAD
