Oil blowing
03-23-2017 | 05:22 PM
Quote:
Originally Posted by
ricktherocket
How did you know they were the wrong gaskets if the rocker boxes are still on?
What were the part numbers on the gasket kit??
I called S&S and talked to them and gave them the part number.. well I had two sets of gaskets 50 50 shot and I thought wrong..
03-23-2017 | 05:24 PM
jefla
Pipe caught my eye, too. Really nice bends and collector. Please share pics when it's done.
will do .. next weekend tip is still a week out .. I am going to wrap them and I am in the middle of cutting some crome down to fit over the collector..
03-23-2017 | 05:33 PM
OpposedOdie
OK the bolts are not plugged.. now the question i have is the vent grove on the tc96 head and the S&S head are different, do i need to look there..
With these heads you also need to enlarge the through holes in the breather bolts with a 9/64" drill bit too.
Gasket kit needed is #90-4120
03-23-2017 | 05:36 PM
ricktherocket
that's the other kit I have...
03-23-2017 | 05:39 PM
OpposedOdie
https://youtu.be/l-xycEwPHnY
OpposedOdie
That is the kit you need with the 89cc heads, #90-4120.
03-23-2017 | 05:44 PM
liquidr1
are you sure you got the lower rocker gaskets pointing in the correct direction. the gaskets have a cutout for the breather path on those heads. if they are upside down they wont line up.
That would spit oil out.
Varooom
08-06-2016 09:30 AM
Steel Wheels
11-16-2014 08:06 AM
Iron lHorse
12-18-2013 05:07 PM
Anezangl
Exhaust System Topics
12-04-2009 12:49 PM
pittguy
12-13-2006 03:46 AM
