Bluetooth
Old 07-23-2017, 02:53 PM
oricko's Avatar
oricko
oricko is offline
Has anyone used this (BT-HD01) with their GPS
  #42
Old 07-23-2017, 03:06 PM
nickrat's Avatar
nickrat
nickrat is offline
I don't have a regular GPS. I do use an app called co-pilot on my phone, it saves maps on the phone so you don't need an internet connection. It works good for me because I listen to music from my phone and the music volume drops when the app gives directions then goes back up.
  #43
Old 08-16-2017, 11:08 AM
oricko's Avatar
oricko
oricko is offline
The Metra bluetooth device will not work with GPS
  #44
Old 08-16-2017, 11:47 AM
rgrecco's Avatar
rgrecco
rgrecco is offline
This thing works GREAT for $13
MPOW 3.5mm Bluetooth Receiver Dongle:
http://www.ebay.com/itm/112307119540
Only thing is you need to keep it charged... You get about 8-12 hrs out of a charge... If you are going on a long trip, add a cig lighter usb adapter to it and you can keep it charged!
USB Cig Lighter Adapter:
http://www.ebay.com/itm/382035821288
I have my phone plugged into the USB Charger to stay charged and cradled in a RAM X Mount on the bars... I stream Pandora and WAZE all the time...
  #45
Old 08-16-2017, 12:03 PM
roussfam's Avatar
roussfam
roussfam is online now
Received 7,225 Likes on 3,756 Posts
Both great ideas
  #46
Old 08-16-2017, 01:33 PM
Lotaluck's Avatar
Lotaluck
Lotaluck is offline
I use the exact set up and works fantastic. Best 13 bucks I have ever spent.
  #47
Old 02-23-2018, 10:00 AM
Stang951's Avatar
Stang951
Stang951 is offline
I tried the bluetooth dongles and charging them from another spot, but I missed being able to pause, advance and rewind from the handlebars and screen. Wasnt difficult to do, but not as easy.
I bought the Saddletramp from Ebay and installed it last week. Works as advertised and sound is good for BT. Like that everything is on the screen of the HK unit. I did find however that I cannot use my CB and the BT at the same time for some reason. I would have thought it would override the BT device from inside the HK radio. I have contacted Metra and am working with a tech to figure that out.
  #48
Old 04-01-2018, 11:40 PM
Redwood2112's Avatar
Redwood2112
Redwood2112 is offline
Has anyone that installed the metra saddle tramp find their volume is way lower with blue tooth than with CD, AUX OR RADIO? i do have my volume all the way up on my phone, wondering if it's my music player or possible install issue. I play the same phone, same volume through aux and I get the same volume as the other sources.
Thanks
  #49
Old 04-02-2018, 10:55 AM
lefty33's Avatar
lefty33
lefty33 is offline
Had a friend trailer my bike to Florida for 10 days of riding back a couple of weeks ago. The Metra Saddletramp worked great as advertised. Worked just like the BT in my vehicles. My CB also worked just like it's supposed to...it did override the BT just like it always has. Not sure why yours wouldn't do that?
Thanks
This is also what I noticed when using it down south. At the time I didn't think of checking my phone volume...I had recently upgraded to a new iPhone. Back in the frozen north now so it will be a while yet before I can check to see if upping my phone volume helps. Even if not, it's a minimal "nuisance" and still very satisfied with it.
  #50
Old 04-02-2018, 12:59 PM
Redwood2112
Thanks for the reply lefty. I wish I could say the same but I could not even hear my Bluetooth on the highway. Cd on the other hand half volume is screaming loud.
Quick Reply: Bluetooth
